Corona Outline Material Through Opacity Maps
I’d like to bring up a possible bug with the new outline material. It seems to disappear from objects that have the material on them, but behind an opacity map.
I.e. this fence has a alpha to represent the metal. The People have the outline applied, yet after the map the people are seen to have no outline, but again, once they are seen through glass they again have the outline material.
See attached
Chris
This is now reproduced and reported as (Report ID=CMAX-1897). What you can do as a workaround is enable the “Clip” option in your material that uses the opacity texture.
(which will also speed up render times :smiley: Always enable Clip for any sort of “it’s on or it’s off” opacity map like a leaf cut out, a fence cut out, etc. Only things with greyscale for partial opacities need to have Clip turned off)
