When you use a Map for distribution of pattern “On/Off Map:” even if you uncheck the “Render Base Object” it will still render the base object.
Corona Version 12 Update 2 Hotfix 1
Also can we get a Rotation for U & V not just W to add extra breakup?
Regarding the on/off map - this is currently the expected behavior. We split the object into “only pattern is visible” vs “only the base is visible”. To “fix” it, you can assign an invisible material to the base object and use another one for the pattern. Corona Physical Mtl or Legacy Mtl with 100% transparency should do the trick.
Note: don’t use the Rayswitch Mtl as it seems to crash (this is now reported).
Regarding U & V rotation - please log it at the Ideas Portal - https://chaoscorona.ideas.aha.io/
