corona pattern possible bug
using on/off map reveals base object while rendering of it is disabled.
A sample scene which we can use and where it can be reproduce will help much better.
here you go
volume_pattern bug.max (52 KB)
This is currently the expected behavior. Can you share what your actual use case is?
