Corona Proxy Bug
I was trying to create proxy from my car and it wouldn’t show me it in viewport.
So i made a video of it.
Could you please fix it.
Hi, does this also happen with other objects or only with this car? Does it happen with some standard geometry like teapot? I just checked and it doesn’t happen for me. Which Corona version are you using? Were you using some other version before, especially A6, or did you change some files, for example the old “proxy exporter bugfix” that you put in scripts folder? I would try cleaning everything (use Corona uninstaller + manually search for Corona files in 3ds Max installation folder and in AppData and remove them), and installing newest version of Corona again.
I have proxies in the scene. It worked fine for me.
But recently it just won’t create even a dummy for corona proxy.
I’m using the latest Corona for student license
Right now i found a solution
I’m copying old proxies and isert in them created proxy files. At least it works
Aren’t these problematic proxies created on a non-renderable layer?
have you tried using the corona proxy exporter from right click quad menu?
it seems like there might be zero scale of the proxy object.
