Corona Proxy Exporter bug with animated OBJ
I found a bug in the Corona Proxy Exporter:
() I have teapot with animated Bend modifier.
) Run Corona Proxy Exporter.
() Default setting.
) Click Export .
() it detect that my obj is animated and he wrote me if I want to continue.
) If I click “No”, it converts my mesh… Eh man, I told you “NO” =) .
(*) Undo.
Bye
Uhm… I’m unable to reproduce this. It has been a while since I wrote the tool but I also can’t seem to find any code part where it asks you a question like this.
Which version are you using and could you make a screenshot of the tool right before export (or record a video)?
Hi
in attachment a video.
In short, when I press “NO”, I would like to come back to the original state.
I don’t want to create a proxy =)
Ahh. Funny, this is not something the script does - it’s max. You can savely ignore it. I didn’t know it pops up at all (it doesn’t do it here), I will have to check if there is a silent option for it.
The collapsing is only happening on a copy of the original object, so it will not affect your original object (only if “Replace source objects” is off, of course).
So the fix is just pressing “yes” :smiley:
Oook! Now I understand!
should get rid of the dialog if it can be ignored
Fixed, please test if it’s really not popping up anymore :smiley:
https://forum.corona-renderer.com/index.php?topic=8683
