Corona proxy exporter error
hello any help? when i want to make a proxy this happend
Which version of Corona are you using? Did you use the official script that is bundled in the installation package?
Hi maru, it is in A6 version, i just click right on mouse and in roll out menu it is last one option - corona proxy exporter, - but when i got 1.00. version it worked.
So now everything works fine?
No, i am now in A6, and when i want to convert something to proxy this error appears.:frowning:
You probably used 1.0, then reverted back to A6. Running uninstall from 1.0 should help… (in C:/Program files (x86)/Corona)
Hi Ondra & Maru, I have the same problem with proxy exporter in A6. I have tried your solution on the same but it can’t help. So please can you give me any another solution ?
It looks like we have two issues here:
  1. Corona Uninstaller does not uninstall the files from C:\Users\Administrator\AppData\Local\Autodesk\3dsMax\2015 - 64bit\ENU\usermacros (maybe it is intentional as these are USERmacros?)
  2. After I uninstalled Corona 1.0, manually deleted usermacros, and installed A6, the proxy exporter is greyed out - the file is missing. Conclusion: proxy exporter is not bundled with th A6 installer. You can also check it by unpacking the A6 setup files.
I will look for a proxy exporter that works with A6. Stay tuned. :smiley:
