DOWNLOAD ALPHA 7.1 INSTEAD
please download new version od coronaProxyExporter
to install replace c:\Program Files\Autodesk\3ds Max 2015\scripts\Startup\CoronaProxyExporterStartup.ms with file attached.
new features:
- *optional add number to proxy object name
- *optional ask for file overwriting
- *optional dialog close after OK clicked (tip: when not closed you may adjust display settings - method and point cloud density - on created proxies)
- few tooltips
- these options are saved between sessions. Same for prefix and lastly used output folder.
changes:
- proxy filename without prefix
bug fixes:
- works with not-English versions of 3dsmax
- proxy name is the same as source object (it was adding 1 to number)
- ignores objects that cannot be converted to mesh (like lights)
- quad menu problem fixed in previous hotfix (item added on every start)
please test and report bugs, so it can be added to alpha 7.1
CoronaProxyExporterStartup.ms (5.74 KB)
