I have created a single proxy from a bunch of geometry, when I create the proxy the version created in-scene seems fine, the pivot point is at the original (model on the left below)
However when I load the .cgeo file in to a new corona proxy object it appears to have been created in Y up and the pivot seems to be in an arbitrary position.
How is this pivot created and stored?
If I’m not mistaken, V-Ray will create a single object proxy as pivot at origin and Z up, so I Proxy created in-scene will have the same pivot point as one created by making a new Proxy object and loading the vrmesh file, this is what I was expecting
Obviously, for now, I can use the one created in-scene, copy across to my new scene and place, but I’m concerned that changes to the bounds of the object will cause a shift in this internal origin, if it’s updated, and hence a shift in the referenced geometry in my target scene.
