I don’t know if topic already exist if yes, please move ma case to that section already exist
if not I want to focus here on reflections if anybody does have any problems with that part of postproduction.
Okay lets start then
I have problem with too strong reflections on my render and I don’t know which render element should be masked to get rid of the reflections marked on pictures, I also include my render elements tab
Thank You for help and suggestions
Regards.
Hi, this looks like the reflection of the mirror’s light source, if it’s a CoronaLight material you can simply disable “visible in reflections”, likewise if it’s a CoronaLight source.
Thank You for reply, Ill let You know if this will help but for now I’m having some 3ds max crashes on start I’m in contact with support so Ill answer as soon as possible
Thank You
Hello again guys,
after a break finally I can answer You
first of all to GeorgeK somehow the option - disable “visible in reflections” didn’t help
I tried method suggested by maru - using both CShading_RawComponent set to “Reflect”
and CShading_Components with the “Reflect” mixing both given some result but the most effective was to mask out “Interactive LightMix” layer
but Ive stopped retouching this render after visiting this bathroom in real life, where I found out that those reflections in real- life re very close to my render so I left it like it is
Thank You for help, I think we can close topic.
