My renders are randomly crashing, can’t figure out why..
Any help would be appreciated, thanks
Corona 10 hotfix 2 / 3dsmax 2024 / windows 11
Date/Time: 2023-10-21 17:39:10 +02:00
Application: 3dsmax.exe
Error: Access violation - code c0000005 (first/second chance not available)
Crashed Module Name: Corona_Release.dll
Exception Address: 0x00007ffbacf1aea6
Exception Code: c0000005
Exception Flags: 0
Exception Parameters: 0, ffffffffffffffff
Edit: Scene is basic, one shader no reflection no displacement. Lighting is an .exr in a corona bitmap map. Scene is not crashing on another node with the same config, same os, same max, same corona version.
Edit 2 :CPU & Ram tested with occt, no error found
Edit #3 : Swapped ssd with another node, same problem. So it might be a hardware problem. Im doing some other tests with the ram (4/2/2/1) had some crashes with two of them but I am not able to reproduce it at every time… Cpu ?
3dsmax_minidump.dmp (9.56 MB)
