Corona Render 6 Dr
I hade face a problem during render using dr
more than 4gb file my file will hang after automatic save in dr process.
Sorry, but I do not understand this report. It is missing basic information. Please deliver it:
  • Which exact version of Max and Corona?
  • How exactly are you using DR? (one workstation, and how many render nodes?)
  • The 4 GB is the size of the .max file? Or the whole project folder with assets? Or maybe it takes 4 GB of RAM?
  • What exactly do you mean by “automatic save in dr process”?
  • Does it hang on the workstation or on the nodes?
  • Does it hang on all computers, or only on one of them?
Please also send full DR logs: https://coronarenderer.freshdesk.com/support/solutions/articles/12000002065-gathering-dr-logs
Otherwise, I can only direct you to the general DR troubleshooting section: https://coronarenderer.freshdesk.com/support/solutions/folders/12000000629
Corona Render 6
In workstation & 4 to 5 Render Node workstation, I m using.
4 GB is Max File size. If I render less then 4 Gb it works perfectly.
when I start the render max file will save on the path C:\Program Files\Autodesk\3ds Max 2020\en-US\plugcfg\ after saving my max will hang.
If my Max files less then 4GB it’s not a problem.
Do you have enough free disk space on the workstation and on all the render nodes?
Can you try running the DR server on each render node and increasing the “max directory size” value?
Exactly the same issue I had here https://forum.corona-renderer.com/ DR Hangs on Save before Render #msg148024
I ended up having to heavily optimize the scene to bring the file size down, once it was under 3GB it rendered fine if I remember rightly (may have been under 4gb)
hello, mi problem is OSL map HDR. When i use this map te dr node crashes.
