With the same max cr version and an empty scene (only a gray blank background), why does “identity” appear?
I finally found out that this happens when 3DS MAX is run with administrator privileges. What is the reason for this?
I am using Corona 13 HF 1 and I tried running 3ds Max as ADMIN but I am unable to reproduce this same thing on my end. Can you help me with the steps so I can try to find out more about it? Also which version of 3ds Max you are using?
