Corona render output
every time I but batch render the render turns from light mix to beauty ; how can i fix it ?
what exactly changes? the image displayed in VFB or the output image?
What are you using for Batch render?
Corona saves every render element when using 3ds max output path, which all scripts/plugins uses for batch, as long as you dont turn off active elements of course.
@ahmed_elheet I have exactly the same questions as Chuck :slight_smile:
