We have just released Corona Renderer 1.5 hotfix 2!
It is available in the usual place: Renderer for architectural visualization - Corona | Chaos
Changelog:
- Fixed UHD Cache settings issues causing splotches/flickering in rendering - if you encounter these problems, press “Reset Settings” in scene render setup after updating to the hotfix 2.
- Fixed problem with .conf files causing error messages popping up in 3ds Max on systems using non-ASCII (like Cyrillic) characters.
- Added tooltips to Corona Color Picker
- Fixed: NaNs (black pixels) appearing in renders
- Fixed crashes when NaNs appeared and LUT postprocessing was enabled
- Fixed: on some machines Corona kept reactivating and crashing when opening material editor
- Non-ASCII characters are now supported in render stamp
- Non-existent directories in autosave path will now be auto-created
- System settings dialog layout fixed
- Fixed small glitch in CoronaMtl UI
- All .conf and .ini files are now properly versioned, fixing problems when switching between daily builds and stable versions
