Corona Renderer 6 for Cinema 4D (Hotfix 1) released
This release addresses the following issues:
  • Added support for R23
  • Added experimental support for R23 Scene Nodes
  • Creating Corona proxy file using “Pick from scene” used incorrect path when canceled
  • Fixed problem with connections between nodes being misplaced if part of the editor is outside the screen
  • Fixed crash when selecting shader from empty shared shader
  • Fixed problem with Corona proxy in Full mesh mode not showing in viewport when its center is outside the viewport
  • Fixed occasional crashes in Corona Bitmap in multi-tiling mode
  • Fixed problem with incorrect photographic exposure when using Team Render
  • Fixed problem with camera name not shown in render stamp when using Team Render
  • Fixed occassional crashes in scenes with Distance shader (usually reproducible in animations)
  • Fixed crashes happening when parsing hair for render
Download now from https://corona-renderer.com/download
