Corona Renderer 6 (RC1) - Corona Material Library Menu
Material Library menu has disappeared. After adding the menu back manually (Customize > Customize User Interface > Menus > …) and saving default scene OR save Custom UI scheme OR save default state, the menu will not re-appear.
3ds Max booting up… (Corona Menu is visible)
3ds Max ready (Corona menu disappears)
This issue is at least specific to RC1; the issue does not appear in Corona version: 6 (DailyBuild Jun 18 2020)
The Corona top bar menu was deprecated and removed in RC1: https://forum.corona-renderer.com/ Corona Renderer 6 for 3ds Max - Daily Builds Changelog #msg173811
You can launch the matlib from the Corona toolbar and even assign the toolbar actions to custom keys now.
Thanks,
Rowan
I thought I might have read that and just forgot. Thank you for the gentle reminder :smiley:
That being the case, why is it that the Corona menu cannot be created manually in the manner I have described - is that a Max issue?
We’ll look into that one as I’m not sure that was intended.
In the mean time you can just give the toolbar a different name “Corona v1” for example and it won’t be removed.
Cheers,
Rowan
