Good day. Is there or will there be support for the version Cinema 4D R24?. Currently, the program does not want to start with the render, if you put it manually in plugins.
The current version of Cinema 4D is S24, and Corona is compatible with it (since 6 HF 2 in fact)
True & through… Latest official v6 (hotfix2) & daily v7 work fine.
And I always use manual installation, so it must be something else.
(°o°)<
Cinema 4D S24 is supported by Corona V6 RC2 and any of the newer v7 daily builds (including the latest V7 Release Candidate 3). - This was tested through all methods of installation.
Make sure that you are not using old software (such as V6 before hotfix).
Thanks,
Jan
