Hi there,
just a question, I want to quickly access the Corona’s VFB, so, I need to reach it via MAXScript.
I found it under interfaces, namely CoronaFp interface, but it seems the interface is inaccessible? How come?
Here’s my simple inspection code:
getInterfaces renderers.current
showInterfaces renderers.current
Interface: CoronaFpTest
Properties:
Methods:
<void>dummy()
Actions:
Interface: CoronaFp
Properties:
Methods:
<integer>showVfb <boolean>show
<integer>resumeRender()
<integer>loadAndResume <string>exrFilename
<integer>dumpVfb <string>exrFilename
<integer>parseViewexp_INTERNAL <maxObject>viewExp <maxObject>outCamera
<integer>setDisplayedChannel <integer>channel
<value>getVfbContent <integer>channel <boolean>toneMapping <boolean>renderStamp
<integer>resetSettings()
<integer>exportScene <string>filename <boolean>renderImmediately
<string>getCoronaVersion()
<double>getStatistic <integer>statisticId
<color by value>getBlackbodyColor <float>temperature
<integer>loadDrIpFile <string>filename
<integer>startInteractive()
<integer>startInteractiveDocked()
<integer>stopRender()
<integer>showLicensingPopup()
<boolean>isRendering()
<integer>reparseInteractive()
Actions:
OK
I cannot getInterfaces() on the Corona renderer’s object. It shows them, but doesn’t return.
Is this a bug? Or a weird feature?
Thanks in advance!
