Hello, I have a simple animation in which I used xpresso for the first time.
When I hit the render button then the images doesnt render and the information
on the interactive render window on the lower left ist flickering, sometimes its even crashing
"The plugin corona4d.dylib has crashed.
More information can be found in
‘/Users/dennisadelmann/Library/Preferences/MAXON/Cinema 4D R19_8DA1506D/_bugreports/_BugReport.txt’.
After clicking ‘OK’ unsaved scene files will be saved as ‘_bugreports/_recovery_xxx.c4d’"
Did you already had a chance to find out what the issue is?
I did manage to look at the file over the weekend and can confirm the issue is with the xpresso tag. As to what exact parameter within the tag is causing the problem I am not sure. However, we will continue to look into it and try to find a solution.
It would help us if you sent us the contents of the /Users/“YOURUSERNAME”/Library/Preferences/MAXON/CINEMA 4D R15_8C725DAB/_bugreports folder. You can zip it and send it to us through the private uploader, for example.
