I’m trying to render a scene I have with Team Render using Corona for C4D on Mac using the latest version A6.3 on R18.
The problem I have is when I use TR it only renders direct lighting as if I chose none for the solver even if I used only the main machine in TR, but it renders fine when I use just the main machine without TR. I’ve setup the same version of Corona on the client and it shows that it started rendering the passes assigned to it so I assume the plugin is working fine. is there something I need to do or is this a bug?
Ali
