Hello, I decided to go back to Corona for a few renders after using Mental Ray.Only to discover that when I save out the render, corona saves it with the system spec and render time at the bottom left corner of the image. Is there a way to turn this off or u would have to crop it in Photoshop?
If I recall correctly,this wasn’t happening before.
In the settings tab. I don’t have Corona open right now and I’m rendering, but it is in there.
Corona VFB settings
turn off the stamp.
Thanks. Is there a way u have it display while rendering but when u save it does not save with it?
It is interactive, meaning you can render with it and when its done go into settings, turn it off and its gonna get removed from the picture.
At least I am pretty sure it is, not by my computer at the moment so cannot check it immediately.
You can turn it off in the settings after rendering has stopped, and it will go away.
I always just turn off though. If I want statistics, I’ll look in the statistics tab.
You can, just remember that if you are rendering on slaves, it will render it with it ON or OFF, depending on your prior settings, and for those that did not get lucky enough, if you strip render with the stamp on, you will get the stamp in each strip!
Just thought you may want to know in case.
