Corona Scatter 3.0 Hotfix 2 Issues
Hello, I recently installed corona renderer 3.0 (hotfix 2) to try out. I’ve having an issue with scattering grass and other objects. corona scatter freezes 3dsmax once i select a distribution surface, is any one else experiencing this issue.
PC specs: Alienware R4, GTX 1070 8gb, 32gb DD4 RAMS
Hi, this is most likely caused by having wire box as the current display mode. You should change it first (to any other mode), and only then select your scatter objects.
This is already fixed in V4.
Hi, please, does it still happening with Corona v4?
