Corona scatter not disabled when hidden (animation).
I have an animated scene and with corona scatter I cannot animate because Corona Scatter makes everything super slow when I scrub the timeline. Despite making Corona Scatter with 0 instances in the viewport and update automatically “turned off” it is still the same. I simply have to delete it form the scene to be able to work.
You don’t need to delete the scatter, you can simply turn it off and keep all the settings. Look for enable checkbox in command panel>modify tab>scattering rollout.
Thanks! Silly me I didn’t consider that :smiley:
Is it possible to share a reproduction scene of this? Can you also please clarify which Corona version you are currently using?
