Corona settings file *.conf
Im not sure if this has been proposed but is it possible to merge a *.conf for the frame buffer from an older *.max or a previous cxr file with the load command in the frame buffer? I try to stay in a close range but sometimes I have so many cameras I need to revert to an older settings file. thanks!
Not sure if I understand the question correctly, but the CONF file is not stored inside the MAX or CXR file. It is just stored separately on the HDD, so you just have to load it.
Sorry what I meant to say is it possible to click load in the VFB and select a max file or another crx file and it will load the VFB settings stored in those files?
Merge the max file into your scene, deselect all the checkboxes in the merge dialog apart from the render settings checkbox.
You can also load from another file in the render settings window i believe.
