We have 2 identical amd machines with geforce 2060 super graphics cards. Both experience a lot of laginess moving the ‘render setup’ and ‘corona material library’ windows around the screen.
Opening a fresh empty Max scene, all dialogues are snappy. Once i change the render engine to Corona, the ‘render Setup’ dialogue becomes considerably sluggish to move around the screen. On 1 machine we have the very latest geforce studio drivers, and the other is a few versions behind but both experience the same problem. All other workstations in the office with different gfx cards do not have this problem.
I’m wondering if this is a 2060 super / corona specific problem?
Sorry to hear you’re experiencing this - we’ve been looking into this, as some of us here have this, but some do not. We’ve been trying to isolate what makes the difference, so far it does not look like CPU, Win version, driver version, or GPU (so far).
Can I ask a question, do you happen to have Corona for C4D installed on those machines, or some other version of Corona (archicad for example), as well as the 3ds Max version?
Hi Tom, thanks for your reply. Interesting to hear that others are having this problem also. We dont have any other versions of Corona installed on these machines, only Corona for 3ds max 2020.
To add to the mix of testing:
One machine also appears to have this problem when the render engine is switched to ‘Vray GPU next, update 3’. The other machine is still snappy on Vray.
Thanks for the info Iain! We’re continuing to investigate and will let you know. So far, this is the only user report, it was noticed internally only so far. All info is good stuff for us tracking down the cause, then the solution.
Hi. Just wanna say that I’m experiencing extreme lag with the Corona Material Library as well. I’m using max 2020, Corona 6 RC2, a RTX 2060 Super, and windows 10 Pro.
It’s not something new. Had this with all Corona versions that include the material library, several versions of 3ds Max (2014, 2016, 2018 and 2020) and on 3 different PC’s with different graphic cards.
Please can you provide me with the following information? I’m trying to narrow down the common factor between all of the systems experiencing this..
CPU
RAM
Graphics Card
Driver Type (studio or game) and Version
Windows Version (Including version number i.e. 2004 update)
Corona Version
3ds Max Version
C4D Version
Additional renderers installed
CPU - AMD Ryzen threadripper 3990X (overclocked)
RAM - 256GB Corsair Vengeance LPX 256GB (8x32GB) DDR4 PC4-25600C16 3200MHz
Graphics Card - ZOTAC GeForce RTX 2060 SUPER 8192MB GDDR6
Driver Type (studio or game) and Version - Studio version 451.77
Windows Version (Including version number i.e. 2004 update) - Windows 10 pro, 2004 (OS build - 19041.388)
Corona Version - 6 (Daily build nov 12 2019)
3ds Max Version - 3dsmax 2020.3
C4D Version - none
Additional renderers installed - Vray next - update 3
CPU - AMD Ryzen 9 3950x
RAM - 64 GB (4x16), Corsair Vengeance, 3000mHz
Graphic Card - RTX 2060 Super, 8 GB
Driver type and version - Studio version 451.77
Windows Version - Windows 10 Pro, v 1909, build 18363.106
Corona Version - V6 RC2
3dsMax version - 2020.3
Aditional renderes installed - VRay Next update 3.1 (Demo)
Updated again to latest windows updates, also updated corona to release candidate 2. Problem still exists.
Interestingly though, I thought I’d test this from home logging in remotely using parsec and the problem seems to disappear and menus are snappy again. Not sure of the reason for this.. local monitors in office are off.
