Corona Shadow Material
Hi everyone,
I’d like to suggest a Corona Shadow Material: a material that makes an object invisible, while its shadow falls only on specific objects chosen with include/exclude.
With new techniques, including AI, our work is changing. We’re no longer just architectural visualizers, we also do product visualization. In product shots, I often need hidden volumes whose shadow affects only the product or one surface, and not the rest of the scene.
Today this means extra passes or fixes in post. A dedicated material would make it much faster and cleaner.
Does anyone else need this?
Thanks,
Matteo Speri – VIZART
Hi, this can be done with the Rayswitch material or map. Can you share more about your workflow, such as how complex your objects and their materials are? Would you have to affect only 1 material or many sub-materials?
PLEASE can we have this!
:slight_smile:
Hi Marcin, thanks!
Workflow: two armchairs on an AI-generated background, floor included, using the Shadow Catcher.
If I add hidden volumes to shape the light on the armchairs, their shadows also hit the floor and overlap the existing ones (double shadows). This works for cars, not for raised furniture.
I’d need hidden volumes whose shadow affects only selected objects or materials, e.g. only the metal frame and not the cushions, or vice versa.
Matteo
I already use hidden volumes in my interior scenes too. To keep their shadow off the floor and only on the object, I often have to raise them off the ground, which is quite limiting. A Shadow Material with include/exclude for shadows would give much more control. Not sure how hard it is to implement, but I think it would be really useful.
Not exactly a new workflow.
If you do not need to exclude reflections and shadows from specific objects, I recomend just turning off “visible to camera” in the object properties.
Maru said rayswich material or map would do the trick, but I do not think it will do what you need.
I was going to explain the old method (cloning the lights and work individually what lights contribute to shadow and which objects), but I noticed that corona is acctually limited in this option on the lights. You can exclude objects from the lights but does not allow control if only excludes shadows, lighting or both like in vray or even scanline.
I did test using vray lights, but the shadow cast being off affects nothing.
If a rayswich material or map with include/exclude objects list is to hard to do, maybe allowing for non-photorealistic adjustments in the light objects would also be an option.
Thanks a lot Victoria, really useful test, and it confirms exactly the limit I’m running into.
To give a concrete example: in my current scene I use lights that affect only specific objects, with gobo textures (tree/foliage) to get certain shadow patterns. But when I want to light a chair in one precise spot, and keep the rest in shadow, I really feel the need for a kind of Shadow Material: an invisible object whose shadow lands only on the objects I choose.
The same goes for the HDRI. It would be very useful to have include/exclude on the environment too, so that one HDRI lights only certain objects (for example the product), and the rest of the scene is lit differently.
The reason I’m asking is that AI is closing many types of jobs, and in my case, and for other colleagues too, work is moving towards very specific product visualization. There, the 3D model has to stay perfectly faithful, while the scene is often built or refined with AI. More flexible control over how light and shadow hit each object would make the integration between the 3D model and AI much more effective.
Your idea of non-photorealistic options directly in the lights (shadows only / lighting only / both, per object) would already be a big step.
Thanks again,
Matteo
