Corona shared material not working inTeam Render?
I have a basic metal material with bitmaps connected as per attachment.
Look how different Team render render to normal render on local machine
Any chance to share the scene? The logs from the clients etc. to see if they received all the textures?
Hi Tom
I tried uploading the scene with your private uploader but for some reason it kept timed out on this side.
I have upload it wirh the dropbox link, please let me know if you don’t get the scene.
Confirmed not working here also.
Confirmed on my end too. I noticed this glitch just yesterday, when I realized that my shared corona noise nodes weren’t appearing on any team render setups. My snowy road was not so snowy as a result. My scene is very complex, so I’ll leave it to Barendby to upload his file as an example.
Hello @Barendby!
We are aware of shared shader not working properly with Team Render. The issue is being investigated. We appreciate your help!
Internal tracking number: 382899521
The other problem is that the textures in the Corona Shared are not listed in the Texture Manager. Vice versa when you “Save with Assets” those assets are not being copied nor links updated with those used assets.
We currently tried to workaround that thing but…you have to check every single channel in the materials to find an unlisted texture. That is hell on earth.
Thank you for reporting this as well! Do you have any other issues with Shared Shader?
Internal tracking number: 384775253
Nothing I know until now, but this problem is (still) difficult for us to handle. Is this anywhere near the top of the “Have-To-Fix-List”?
Same Problem here
https://forum.corona-renderer.com/ Bug with Corona Shared Node
and here
https://forum.corona-renderer.com/ Node Problem
i dont know why this is fixed yet! This is some minor bug,
Imagine you render an animation and realize only a day later that a certain material is not
on the object. (and imagine you do not know about this bug…)
Check my post https://forum.corona-renderer.com/ Projector shader
Hello @Barendby
The latest V5 daily build should fix the issue! You’re welcome to test it. Please, let us know if it works for you.
Installation link is here: https://forum.corona-renderer.com/ Corona Renderer 5 for Cinema 4D daily build - Changelog #msg156272
Slava
Hello Metopa,
Please download the demo scene from the first post
with latest beta 5 Daily Build 2019-09-20)
Team Render - works
Corona IV - works
Corona IR - works
Render in the edtor window - works not
Hi tuami,
yes, this issue is directly connected with the Team Render. So I’m happy to hear that it works. The issue that you linked is still being investigated.
Cheers,
Slava
