Using v8, when I turn off “Visible in reflections” the object is rendering white and this error message comes up:
===== Warning(-19) =====
An internal error has occurred causing your image to contain NaN (Not a Number) value.
Please report the bug with the scene attached. We can fix these problems promptly if we have the scene where it happens.
It seems to only occur with certain materials. Furthermore, clicking on “Create bug report ticket” does nothing.
it renders with all objects totally blown out(white)
the usual Nan error message appears, , not sure what to record?
i have a sun, a sky, set to give gi, and a hdri in sky object that acts fro reflection/refraction and as BG,
the scene is big, but renders fine in r23 with corona 6
Here is the scene in which this error occurs. https://1drv.ms/u/s!AtQc0dCHh4Jfj6tqvFP2qNOPQ23RdQ?e=EKgbax
The problem disappears if you enable Visible in refractions on Corona Sky or reduce Roughness to 0 on material that has Refraction enabled.
Until version 7 Hotfix 2 everything is fine, since the first builds of 8 this problem appears.
