Corona Sky object - Direct visibility override in render sttings doesnt work
Corona Sky object active - Direct visibility override in render sttings doesnt work.
Simple Color/Physical Sky/Shader HDRI - all the same problem
If visible directly in the Corona Sky Object is unchecked the override materal in the render settings is visible.
5.0 rc2 PC Win10
Hi, Thanks for reporting this. We discovered this yesterday and it’s internally tracked. (Internal ID=425822412)
Hi there, can you please check this in V5 (official) and let me know if it’s solved for you? Thx
