I sometimes use Corona select Texmap in environment slot to combine different hdri and CoronaSky maps for different camers.
The problem is when CoronaSky has Volume effect turend on, Corona renders it even when diferent map (for example some hdri) is active in Corona select map.
This only happens when CoronaSky is used in Corona select map.
