Hi i compared the build from 2014-01-14 with the build from 2013-12-12 and there are differencies…
I dont know whether it is a bug. It is exactly the same scene with exact the same texture. I used a floor material with a normal map.
Thanx
I did some changes/bugfixes, so it is possible that the new version of the image is without some bug ![]()
Can you upload a simplified version of the scene?
Here it is!
All textures are in…
StandaloneTungeeTex.zip (5.22 MB)
ok, the problem is that you use bump map as a normal map. When I remove it it is fine
