Here is a small kit i made to ease the lighting with corona render, it’s available now for free!
Some features :
• Softbox Area light, for better reflections and easy controls
• Combined and adjusted sun and sky rig,
• HDRI loader with some viewport feedback
• 15 pre lit Studio Setups to get you going
• Entirely built around Interactive Render
Few things I have noticed here and would give some marks:
-Some stage materials have no reflection at all, everything should have reflection, even the slightest value, so I would put something like 0.2 as default.
-It would be nice to have IR option force path tracing as default, so ir updates would be quicker without losing much.
Thanks for the feedback!,
I suppose both of these options can be easily defined by the user, the preset scenes are only a base to show an efficient use of light distribution
This is so cool. I loved using your VRay Studio Tools product and had used that as a basis for making a Corona version. But now I have this too.
Thanks for being so generous.
Thanks for the heads up, you can swap the path with the corona library path instead!
i must have not noticed this one since i happen to have the octane library installed (which is also free btw!)
Unfortunately i don’t have Max at the moment, but perhaps someone with 3ds max experience can put together something
similar based on this using maxscript?
