corona sun angle
Although I do prefer the new method for moving the corona sun around, I do sometimes miss being able to type in the angle… what about having both?
It would serve as a handy reminder to what your vertical sun angle is, and you could type it in as well for more accurate control.
If this isnt clear I’ll try and explain it better
pg
I miss it too but you can now type it in rotation slot (in 3dsMax, the bar in top down under viewport) when you uncheck targeted.
But even then the rotation is from vertical… so 30 degree sun angle is 60 degree.
Maru added additional controls to sun object: Target CoronaSun - Corona for 3ds Max :: Requests - Chaos Forum
Don’t see a reason why it can’t be done officially, though.
thanks guys, that helps a lot.
would be cool to have what Maru did added officially
for sure its quicker and more intuitive now, but many people I’m sure have different sun angles set up for different cameras - so numeric entry is often better for that.
If I had to vote for one or the other, i’d go for the previous one, but if we are sticking with this new corona sun then having numeric entry (similar to maru’s scripted thing) would help a lot.
(using it in non-targeted mode as Juraj suggested is a massive help - i just need to subtract my sun angle from 90)
i’d definitely like to see it added anyway. Little things like this make all the difference. When you are adjusting things like that 50 times a day then the mental arithmetic toll adds up
It’s not the same because I am rarely in rotate gizmo mode. So when I need to change the sun, I need to also change into rotate mode, ideally also the correct space. That’s two, or three clicks as opposed to one. Plus doing small math. It’s just annoying since sun is such an important asset to work.
This is true if one uses pivot point center. Try it with selection center or transform coordinate center and your sun object may rotate in a quite unexpected way. This is definitely less convenient than simple controls in modify panel.
