Corona Sun Light and IES light
Hi everyone,
i am using C4D R18 and latest realese of Corona 3 Hotfix 1. i am using Mac Pro late 2013. i was using El Capitan and Corona was working with it. 2 days ago i upgrade my OS to Mojave. After that Corona starts crashing. i realised that when i use Corona sun it crashes. in my projects i have Corona sun. when i open my projects if i have a change… it renders but without sun light. it only renders the sky light and i can not see the sun. But i can use HDRI images or other light sources.
My second problem is with the ies lights. i can render the ies lights but when it comes to render the scene in a renderfarm i can not see the ies lights. They all change to normal Corona light.
i really need help. any idea ? anyone having same problem and solve it ?
thank you
The IES light sounds like the IES file is not being sent to the slave / client / farm machines. Check the standard C4D settings on sending assets for Team Render (or if it’s an external render farm, on their requirements for how a scene should be packed to include IES files along with it)
Thank you very much for your answer. i am using a renderfarm that package my scene automaticly.so i can not change the file. i will contact with them.
Thank you
