I have a Corona sun and I would like to preview the shadows it produces in Open GL.
Firing the interactive renderer is not an option because the parsing stage takes too long (I’m working on a large and complex file)
Can anybody tell me how can I preview the Corona sun’s shadows in Open GL… or maybe how to recreate the shadows a Corona sun would produce with a Cinema 4D light.
Just as beans advised.
It’s actually pretty simple if you add a sun/time tag to the corona sun. Then you can set the same date/time in both of the objects and use the c4d sun to cast the viewport shadows.
Many thanks for your answers Eddoron and beanzvision. Now I can work faster with my shadows!
I’ve just got one more question.
Instead of the sun tag, do you know of any other tag that would allow to control the direction of a C4D light (in a similar way the Corona handles the direction of the light…)?
The thing is that I very much like how Corona controls the sun via the rotation and angle inputs. And when I use the sun tag one need to also fiddle around with the dates…
Thanks Eddoron, then I will fiddle with the dates and time… This way works quite good. At least I get a preview of what I will be getting with my Corona Sun without having to render.
Is it possible that only one sun tag affects the Corona Sun and C4D Sun? I ask this so that I don’t need to copy or replace the Corona’s sun with the C4D’s sun tag
[b]!!! BUG WARNING !!![/b]
IPR constantly restarts & flashes
it stops, if you left click & any menu opens or, if you hover and circle over IPR, viewport & around… like a fearless eagle, watching thunderstorm beneath
enjoy
PS feature requests
Maybe developers would kindly hack it in under option: Enable OGL Shadows
Also, i still don’t understand why Sun & Sky are separated, since they are in more than 90% of cases used together… just add on option either to override and/or disable each. Ahhhh… so much wasted time clicking… settingSUN.zip (198 KB)
holly cow burnin! you’re the man! many thanks! this helps me loads!
I just need to try it out with the take system… I guess it will work just fine. The thing is I have lots of takes and for each of them I’m changing the sun tag properties. Before your Xpression I had to change the tags twice to have a proper take. I hope now I will only need to change one and the two tags will coordinate in the takes…
it works fine… now, if IPR would be working properly i wouldn’t get pissed every now & then, when i visit and open this abomination
luckily, found my peace in blending openly and this is gathering dust…
edit
hmm… maybe there will be 1 frame offset… i remember cinema having problems with some rigs, particles, sims… occasionally, but am not sure anymore with what specifically, hopefully all will run fine
You got it all mixed up, man! What you really intended to say is: “If only Xpresso was implemented properly, then the Corona IPR wouldn’t have any trouble with it”
