Corona test
Hi guys!
This was a test I did with the Corona converting a scene that originally made in VRay, and converting materials and lighting for Corona.
Very nice renders man, like them, can you share your curtain material?
Also if you can tell lightning for this scene :wink: HDRI or CoronaSun and Sky
Hi mga!
This is the material used in the curtains and then I put the shader in the contributions section.
As for lighting, use a Corona Sun and Corona Sky. The HDR was used only as environment.
Thanks man, and keep up the good work. One last question, are you using CoronaLightMtl for background?
No mga. Only HDRI image.
