Corona Tile Problem
Hi, why the new feature corona tile work (for me) only on vertical surfaces? i put the same material on the floor and i see only vertical line, but if i rotate the same mesh in vertical seems work.
maybe i wrong some projection?
I used world in the tile parameter and UVW in the object projection,it’s correct?
Hi there.
Please make sure to use the correct projection mode (UV plane) for the Corona Tile Shader.
If your plane object is vertically aligned, then I’ll suggest using the XY or ZY mode, and if it’s horizontally aligned then use the XZ mode for it.
I hope this helps.
Please let us know the outcome.
Kind regards.
It’ work! Thank you!
I’m glad it worked.
You’re welcome.
Have an amazing day/evening.
