Corona Tile using vertical and horizontal images, Bug?
I dont know if this is a bug or just lack of knwoledge from my side, so here it is.
When using corona tile with vertical bitmaps I cant rotate them into the correct position to make Corona tile work.
What I have tested, the Rotate in the Corona tile, the tile randomization rotation and also using a corona randomizer rotate option…
Only way for it to at least show, BUT its not the correct format orientation.
THE way it should look, Only achieved rotating the original maps outside max/corona.
I’m not sure if i understand the issue correctly, but making vertical tiles in Corona is easy, you just rotate W coordinate in both, Corona tiles map and in texture node (assuming that texture has vertical aspect ratio). Hope that helps. Scene file’s attached.
corona-tiles-vertical-horizontal.7z (102.5 KB)
I forgot to attach the textures.
textures.7z (22.0 KB)
Thx for the reply, but its not working for me, and if I need to change the W rotation in 40bitmaps Im sure there is something missing here..
In this first screenshot i got the W rotate on 90 in the corona tilemap too, and the result is just bad
The only way I found for it to work is to rotate the textures and then load them, here are two of the bricks im using, if some one can lend me a hand I would be really grateful !
Do you mean that my scene is not working, or that it’s not what you need? I not quite understand. I think your task should be achievable without rotating textures destructively outside of Max, but maybe i just don’t understand what the end result should look like.
You can load 40 bitmaps in Corona multimap, then pass it through mapping randomizer to rotate them by 90 degrees all at once. That should work the same as rotating each bitmap individually.
Is that what you are looking for?
vertical tiles.7z (277.2 KB)
Hi Romullus, can you downgrade to max 26 Please
Sure thing.
vertical tiles.7z (278.7 KB)
