I have an animation in Corona which I would like to render in Vantage. I’m finding that I have no way of controlling the exposure of the animation at all. I open my scene in Vantage via Live Link and its over exposed (needs to be -5 on corona camera simple exposure). I know I can control it in Vantage, but when I come to render it via ‘Vantage Anim. export’ button it opens in Vantage over exposed with the render dialogue box open and if I close it to change the exposure settings and open it again I can’t render an animation as ‘sequence’ is greyed out. Is lowering the lighting settings the only work around or am I missing something? Any help is much appreciated, it’s entirely possible I’m missing something obvious.
You could enable auto-exposure in the Vantage render window if this is good enough for you.
If you start the live link in advance, adjust the exposure in Vantage and only then run the animation, does it still get reset (I’m guessing a bit here because I don’t have Corona, maybe it doesn’t work quite like the V-Ray link)?
In any case this is already registered as an issue by the Corona team (CMAX-1758 ) but I can’t give you an ETA for a fix. You can also write in the Corona forum for such issues because it’s usually something that needs to be handled in their exporter.
Thanks for the response. I haven’t tested auto-exposure yet, it will be the next test I do, but I’m a bit concerned it might vary between frames and lead to an inconsistent/flickering animation.
If I start a live link then I can’t render a sequence as its greyed out. I should double check this though to be sure.
