Corona Tonemap Control not working on interactive
Hi, i found a bug in the corona tonemap control map
Just put a direct visibility override and a bitmap with corona tonemap control map. Start the interactive and change exposure with all the thinks unchecked, the background WILL be affected by the exposure, for it to properly work you need to disable and then enable the controls on the corona tone map control maps
I made a small video for it.
Did you read warning text in the tonemapping control map? “it also does not support changing tone mapping after render has started - restarting render is necessary” ;]
Man, sorry :frowning:
