i decided to continue my issue from here https://forum.corona-renderer.com/ Daily builds version 2 #msg125052 i hope it is necessary to bump this thread.
hi devs or mike288, yesterday i tried every advises in this thread and nothing changed but after i installed max 2018 idly, surprisingly corona toolbars isnt broken. so, could you please take a time to investigate this helpful-feature issue?
default win program files: c:\Program Files
max 18: I:\Program Files\Autodesk\3ds Max 2018 -corona toolbar isnt broken.
max 16: I:\Program Files\Autodesk\3ds Max 2016 -corona toolbar is broken.
note: other than corona toolbar is working including corona material library.
I just did uninstall max 16 and corona and clean everything related in c:\users<name>\autodesk.. And now surprisingly it works.
But there are doubled items in corona toolbar (sorry each duplicated items are already deleted and i forgot to capture the screenshot).
and sorry i mistakenly read this thread title, i thought it was about corona toolbar.
Hi, to get rid of the doubled icons you can reset the whole toolbar by deleting it from Max - see the solution number 2 at https://coronarenderer.freshdesk.com/support/solutions/articles/12000042151-the-corona-official-toolbar-is-not-working-correctly-
But this thread is no about toolbar. Please, create a separate thread for further toolbar-related questions/comments. Thanks.
hi mike,
thanks
i think one of factors causing my problem is i frequently install 1.7 and v2 daily build everyday.
yes sorry
I’ve split the topic. You can continue to discuss it here.
