Corona Toolbar for 3ds Max
Hi Everyone,
I would like to share Corona Toolbar for 3ds Max
Corona Toolbar v1.5 for 3ds Max 2017
Download:
Corona Toolbar v1.5 for 3ds Max 2014 - 2016
Download:
Changelog:
Changed Corona Interactive Render Button
added button Displacement Modifier
added button Denoise None/Full
added button Distributed Rendering Enable/Disable
added button Corona Converter
added button Scatter Lister
Corona Toolbar v1.0
I can’t download files from this link
great tool bar many thanks!
Fantastic job …Thumbs up mate…!!!
Well done, thanks a lot !
can anyone confirm if this works with version 1.2?
That toolbar should be packed with Corona .. Nicely done .. Thanks :smiley:
I can confirm it works.
I have one request though, very minor - if you open max and have not yet rendered anything in that session with Corona, (i.e. there is no existing VFB), then when you hit the Show VFB button nothing happens. In other words it will only work if you already did at least one render, since it’s only showing the last VFB. I would ideally like it to open up a fresh one if possible, regardless. Although it really doesn’t exactly matter, I just wanted to check the buffer before doing any rendering.
Nice job !
To be installed straight away :smiley:
Thanks! That will save me (i calculated) 42,328 mouse clicks /yr. :wink:
Could I please request some additions to this fantastic Toolbar?
  • could you please add Nik684’s brilliant Affinity Switch if he allows it
  • could you please add a simple switch to turn on and off Distributed Rendering
  • perhaps a simple button to edit Render Region and depress it to turn it back to View mode
Is this link dead? I get a 404 :frowning:
Can anyone reupload this plugin? Looks really nice.
Link is alive, just tested it. Maybe try again later?
Thank you!
Hi.
I like and use your toolbar a lot. It’s great. I now changed to max 2017 and unfortunately there are no icons for the toolbar, just plain text. Any idea why?
Oh and the buttons are also not working.
Thank you.
Support for MAX 2017 please!
works with 3ds Max 2017 without any problem
For me the Corona Render 1.4 Bugfix 1 fixed the problem : )
Update Corona Toolbar v1.5 for Max 2017
