As in the title, a small test FOR FUN of different Corona version.
What it’s strange is the v1.7 NL. In both v1.6 and v1.7 it’s 8.14.
But the v1.7 has, clearly, less noise, especially on the ceiling, left /right walls and in the DOF.
Is it a bug?
the noise estimation is not perfect, so when we improved the sampling in 1.7, the measured noise remained the same, even though the picture is much clearer
Great tests Cecofuli!
The 1.3 shots appear more “smooth” because of different filter type or size, right? It could be probably easily fixed by enabling blur+sharpen in 1.6+
I am also curious how this test scene would behave with “render until it’s clear” scenario, rather than setting a fixed time limit. That could be however tricky to setup, especially now that the noise level requires different values across different versions.
adaptivity: different part of the same image could be more noisier in 1.3, post-1.4 the noise is more or less uniform across the image. How to test this: look at the rest of the image, isnt the noise pattern reversed somewhere?
image filtering: we were previously blurring the image during rendering to reduce noise, but that was not compatible with adaptivity. 1.6+ corona has the option to apply the same blurring as post-effect interactively. How to test this: disable image filtering in 1.3 and rerender, is it more noisy?
GGX vs. older, more primitive BRDF model. How to test this: does it happen also when the scene is not glossy?
Take a look at sharp edges on Cecofuli’s tests. 1.3 is simply more blurry. With that in mind, you cannot really judge how noisy it is.
I am attaching an example of 1.6 hf 2 with and without adaptivity. If anything, it becomes more noisy with adaptivity off, so I don’t think re-running the tests with adaptivity off makes sense.
v1.3 has default Filter setting, with Width 2.0.
I think that Filter Type isn’t so important.
But, it looks like, with the same Filter width, the v1.3 add more “blurry” to the pixels.
So, it was better make the test with Filter width=1, in all version (Sorry)
Ohh.. I’m so stupid! Ahaha.. you are right! But, today I had a very crazy day (really crazy)!
But, I agree with you. Adaptivity should be improved a bit in my opinion.
A classic trick we sometimes use in VFX when dealing with dark images in modern renderers is to overlight the scene (expose up every light relatively) to make the render go faster, then in comp to expose down the image back to ‘normal’.
Is this a fair comparison? Low res render with object/shader/texture and lighting complexity more or less equal across the screen?
AFAIK the purpose of adaptivity is to clear up complex objects in a simple scene equaly so that you don’t end up with clean render and couple of noisy objects taking ages to get at acceptable level. I tested adaptivity on/off on couple of scenes yesterday and it worked as expected…
Or are we talking about adaptivity being broken? So that it slows down rendering in the long run?
Well, that’s what I thought. Just got a little confused with these comparisons against 1.3 i guess…
However, did a little “tweak” to Cecofuli’s scene to exaggerate the adaptivity on/off difference by adding a complex object (Oats’s Zygote) with close to a hundred 4K UDIM textures loaded through max’s composite node. Throwing the balance of complexity on screen a bit more off…
The results are as expected, however I have to say it seems to me that the clarity on the creature doesn’t seem that much better with adaptivity, while everything else is much more worse…
PS: off topic but is there a better way to load UDIMs?
And shouldn’t denoising also be factored in? The biggest purpose for adaptivity that I see is to allow denoising to do its magic, and that saves a lot of render time.
Maru, I think (but I’m not 100% sure) that Filter width is different that from Blur/sharpen.
Blur/sharpen is a post-production tool, and Filtering is something who works at sub-pixel level.
About denoising, my test was intended to compare the quality of noise between the last Corona version.
Wait, so all this time adaptivity may have actually been making images noisier, overall? I guess it’s my own fault for taking it for granted, and not reading more/doing tests but I just thought adaptivity would add more samples to areas where they were needed - but this tradeoff doesn’t seem like a good deal at all if the comparison renders here are correct
No, you thought correctly. Adaptivity is Gold if you have the Enviroment texture visible. With no adaptivity you would be non stop sampling the enviroment, although it never actually needs to be sampled, thus wasting power. All in all it almost always worked great with what it did.
For me Adaptivity fails with being too sensitive sometimes. For instance here.
Although it’s about caustics it still holds true for some interiors. Noise is most visible on non textured uniform surfaces - i.e. Walls. There Noise pops out very strongly. But technically the Noise is not “more” there. It just is very visisble compared to a blank solid wall.
For many interior scenes with glossy surfaces near windows, the reflection of the glossy surface gets over 10x the processing power compared to the wall.
But the reflection of the glossy surface is barely visible even though it may have high noise levels. But the Solid color wall with maybe only 3% noise is still apparently noisy, but won’t clear out until 500passes, because that reflection of the glossy surface gets everything.
Yet still Adaptivity works fine in most other cases.
In my test, there is a big glossy column inside a DOF area.
Try to render this scene for 1 hours (not 5 minutes) with:
Adaptivity OFF : very clean white wall, but the noise in the DOF is too much, compared to the rest of the scene
Adaptivity ON: wall is a bit noisy, but the noise is more uniform and pleasant.
