Corona V4 - not supporting our scripts
Hey there!
Congratulations on the new version! Love the loading times of the scenes for rendering!
Unfortunately it does not work with our scripts.
Here a little description of the problem:
We use scripts for rendering product images, based on multi-sub materials, where the script launches the same scene
multiple times changing the objects material.
Now with the new version it gets stuck on the first one and does not switch to the next one.
It would be great if you could let us know what could be the solution for this.
Lucas
I am afraid we would need more details on what exactly you are doing, and what kind of errors maxscript is showing.
If you cannot share your scripts publicly, could you please contact us at https://coronarenderer.freshdesk.com/support/tickets/new and provide an example script, or the problematic part of it?
Dzięki,
Marcin
Thank you for reply Maru, the problem is that the script does not give any errors, Corona just pauses in the moment
where it should be re-opening the scene and starting it with different parameters.
Do you want me to send you the source code for it?
Lucas
(handled in support ticket #26089)
