Corona v5 interface problem
Hello.
I would like to learn corona, but I’ve got a problem. On Corona Doc | Corona Renderer I see different interface than it is in my 3d max. What should I do to change it like in documentary?Even post production settings are different and I can not find intensity multiplier and highlight burn. I know it is probably easy to change, but I can not find solution.
](http://postimage.org/)
1st. attachment - online documentary
2nd. my 3d max render settings.
Thanks in advance.
This documentation is old an should probably be removed.
So there is no any documentary which can help me with this render engine? Only forum?
most of the options are pretty the same, some are just renamed. There is currently no actual exhaustive reference manual. Hopefully it will be done again for the next release :wink:
Thank you. First tests make good impression and gives enthusiasm to study it more. I think this topic can be errased :smiley:
