Hello guys,
i gave a chance this new tools and really trying to make it work.
Question:
When Roughness maps in Live Link will be fixed? (now using map i base color makes roughness map not work) → you have to use Export Scene and then standalone Vantage.
When will Corona AO or Curvature work?
Edit:
Also translucency is not 1:1
Also hdri map to match Corona has to rotated 270deg inside Vantage.
The roughness issue is already logged in our system (Report ID=CMAX-1460)
For Corona AO and Curvature, please log a feature request here: https://chaoscorona.ideas.aha.io/
You will need to pick “Add a new idea” and describe your feature request in detail.
Regarding “translucency is not 1:1” can you share more of your setup? are you using Corona Physical or legacy mtl? Which version of Vantage and Corona you are using? Can you share a video showing this issue?
Regarding “hdri map to match Corona has to rotated 270deg inside Vantage.”. This is now logged in our system also: (Report ID=CMAX-1664)
How are you applying your HDRI in 3DS Max? We usually use a CoronaBitmap, control the rotation within that, and plug it into our Scene Environment. See image HDRI 01.
If you compare the rotation of the result in Vantage in image HDRI 02, you can see they do not match.
Are you using a different method which might be giving different results? I have tried it with a normal Bitmap as well, still the same results. I am having to rotate the HDRI by 270 degrees within Vantage. Which then resets when I move anything within max.
Do you mean that numbers/degrees do not match, but live link in Vantage and render in Corona are correct?
If it is just about numeric value, it is just how Vantage interprets rotation - it’s clockwise and counter-clockwise logic, which can be different from software to software.
