There’s small problem with Corona VFB during animation rendering.
If it’s ON in settings then it will be for the whole animation rendering time.
However if you switch it OFF in settings then previewing the render becomes pain - especially if it’s a quick frames. Basically you click “show VFB” to see what’s rendering but it switches off when it goes to next frame. So you end up hitting it to view the rendering.
Request:
To make the VFB acting the same as in scanline or others (during animation render). So opening it will keep it open for every next frame and visa-versa closing it will keep it closed.
