Corona VFB Shortcut
Hi all,
Does anyone know a way to assign the Corona VFB to a keyboard shortcut or a Quad-Menu link?
I find the regular process to be a bit fiddly with clicking render settings>scene tab>Show VFB
Has anyone got around this? I get nothing in the listener when I open the ShowVFB button to be able to make a small macro for it…
Thanks in advance,
R.
macroScript CoronaVFB
category:“Corona”
toolTip:“CoronaVFB”
CoronaRenderer.CoronaFp.showvfb true
Copy this into your maxscript editor window, select all the text and drag the text into your toolbar, it will make a button you can change to a VFB image or whatever, off you go
showVfb show Displays or hides the VFB window. When the argument is true, calling it is the same as clicking “Show VFB” button in the UI.
I know this is not exactly what are you asking for, but this what I prefer to use : (Corona Toolbar)
https://forum.corona-renderer.com/ Corona Toolbar for 3ds Max
I think this should be installed by default with Corona Renderer :slight_smile:
Hi Guys, thank you for all the answers, I should have dug a little deeper on the Corona Rendering Core section!
Thanks all and have a great day! :tongue:
I couldnt live without that Toolbar.
Easy to start the IR, open VFB, enable/disable DR DeNoise…
Just cant live. or is it ken lee https://www.youtube.com/watch?v=FQt-h753jHI
Agreed - a must !
Any plan to provide a Corona toolbar out-of-the-box ?
An additionnal button to create Corona Camera would be useful as well :smiley:
Another little addition I was thinking about, for the IR button. It would be great to add an optional mode for this button, available by keeping left mouse button clicked, which would launch IR mode locked to current active view. That would prevent from switching to Render Panel just to lock the view …
What do you think ?
Really, an out-of-the-box toolbar becomes crucial, ergonomy-wise.
Regards.
