CORONA VFB
Hi all,
I have a question in regards to the Corona History function in the frame buffer.
Every time I press to save the current image, I am working on, it deletes the one that used to be there before.
Also is there a way that you can access those saved images somewhere?
Thank you!!
Can you tell us more about the issue? What resolution is this? How much free RAM do you have during rendering?
We have a similar one running in our support right now, and there is also a bug report on Mantis about it, but it’s a bit mysterious, since sometimes it is possible to reproduce it, and sometimes it is not…
You could try going to System > System Settings button, and then increasing “Size on HDD” under “VFB Settings”.
The images can be found in C:\Users_username_\AppData\Local\Autodesk\3dsMax\2017 - 64bit\ENU\en-US\plugcfg\corona\history
Thank you for your prompt reply.
It was actually the Size on HDD!
I have just realized though that every time I close the file that I am working on the History gets deleted automatically from the system.
So when I open the file again I cannot work on the one I saved already!
Is there any suggestion for this issue?
Thank you.
