When Corona Volume Grid bounding box touch ( pierce ) plain wrong shading on plain.
If not touch ( pierce ) - all good .
Look at pictures.
Its bug or what ?
Corona 9. С4D R25.120
Hi there, this is an old issue that we are aware of and have it logged.
(Internal ID=910407615)
The workaround is to ensure the bounding box does not intersect with other objects.
Hi, I came across the same issue. I’d appreciate if you could fix that soon. In the current state it would require a lot of postproduction to make it usable, in some scenarios.
Nevertheless, possibilty of a cooperation between C4D Pyro system and Corona is great!
Best,
Lukasz
Hey there,
I’ve found it seems to be linked to IOR of the intersecting material - may be a fix here somewhere
(Internal ID=910407615)The workaround is to ensure the bounding box does not intersect with other objects.
Corona 9 Hot fix 1 come out. And this bug still here .
Why you dont fix this bug so long time ? It was in Corona 8 and may bee before 8 .
In most cases its not usable . Because vdb object is in the middle of bounding box. And I need to put it close to the ground or wall .
